How Can I display Hello World Text On my Hologram app?
How Can I display Hello World Text On my Holographic app, this text "Hello World" need to displayed dynamically at runtime, for example this could be a twitter feed.
Patrick mod
You can also use a 3D text mesh in Unity, and enable/disable the game object that has the text mesh to conditionally display the mesh.
Here's a cheesy debug script I use sometimes:
public class DebugText : MonoBehaviour { /// <summary> /// Unity textmesh for rendering text. /// </summary> TextMesh textMesh; /// <summary> /// Counter for number of frames. /// </summary> int frames; /// <summary> /// Tracks FPS. /// </summary> float fps = 0; /// <summary> /// Tracks which whole second we are on. /// </summary> int SecondsPassed = 0; void Start() { textMesh = gameObject.GetComponent<TextMesh>(); } void Update() { // This is a super crude method of determining FPS. // Basically, we count how many frames we get each second. frames++; int currentSecond = (int)Time.time; if (currentSecond != SecondsPassed) { fps = frames; frames = 0; SecondsPassed = currentSecond; } // Also show available speech commands. textMesh.text = string.Format("fps: {0}}", fps.ToString());, } }
and then I make an object in the Unity editor and add a TextMesh as a child with the above script. On the parent object I add this script, setting the text mesh as the 'information object' so I can toggle it with my keywords.
/// <summary> /// Creates a handy debug window. /// </summary> public class CommandWindowController : MonoBehaviour { [Tooltip("This object is shown when the command window is expanded")] public GameObject informationObject; [Tooltip("This is the offset from the user's position to draw the object")] public Vector3 headOffset = Vector3.zero; /// <summary> /// We will be using speech for some interactions. /// </summary> private KeywordRecognizer keywordRecognizer; // Use this for initialization void Start () { // Create the keywordRecognizer listening to 'expand' and 'collapse'. List<string> keywords = new List<string>(); keywords.Add("expand"); keywords.Add("collapse"); keywordRecognizer = new KeywordRecognizer(keywords.ToArray()); keywordRecognizer.OnPhraseRecognized += KeywordRecognizer_OnPhraseRecognized; keywordRecognizer.Start(); } private void KeywordRecognizer_OnPhraseRecognized(PhraseRecognizedEventArgs args) { // Enable the appropriate objects when expanding/collapsing. switch(args.text.ToLower()) { case "expand": informationObject.SetActive(true); break; case "collapse": informationObject.SetActive(false); break; } } // Update is called once per frame void Update () { // Put the object in a static position in the scene relative to the user. // Generally this wouldn't be a good idea for an application, but this is handy for // debugging. Transform headTransform = Camera.main.transform; this.transform.position = headTransform.position + headTransform.forward * headOffset.z + headTransform.right * headOffset.x + headTransform.up * headOffset.y; this.transform.LookAt(headTransform); this.transform.Rotate(0, 180, 0); } }
7
I would start looking into MVC/MMVM patterns and things like uGUI and Text Mesh Pro.
@ManojTalreja sounds like you are looking for Unity UI.
Look at the create dropdown at the top of the Hierarchy pane.
BUT.. there are a lot of weird issues that you will need to fuss with.
If you add a text element, it will put it inside a canvas as a container.
Set the Text property of the text object to Hello World.
To programmatically set the text property do something like:
where "Text" is the name of the Text object in your Hierarchy.
Default uGUI text is a good option for "Hello World" apps, but for production apps I would use a vector-based text plugin such as Text Mesh Pro, which is compatible with uGUI.
@HoloSheep Hi there, I have exported the HoloToolikit-Unity package into a new blank Unity project, as well as a Canvas and Panel (in ScreenSpace-Camera mode and HoloLensCamera prefab as RenderCamera) but I cannot change the position of the Canvas. You say "zero out the position of the canvas" but mine is greyed out. What am I missing?
