Saving and Displaying Spatial Mapping Mesh
I'm trying to save the mesh created by the hololen's spatial mapping feature. What I want to do is the following
- Map the room for some period of time
- Save the mesh created by spatial mapping
- Display that mesh as a hologram, e.g. a miniature version of the map
I am aware that you can download the mesh as a .obj file from device portal, but I need to do this within a script.
What I have been trying, with limited success, is calling SpatialMappingManager.Instance.GetMeshes(), then drawing these meshes in a new gameobject.
The problem is, when I draw the meshes I capture from the spatial mapping manager, they draw as a completely unrecognizable, jumbled mess in a cube.
So I'm capturing something, but when I draw it the output is not at all what I'm expecting, and least of all a map of the room I'm in.
Here is some of the code I'm using:
//this runs after mapping the room for some period of time. if(stopCount == 1) { stateDisplay.text = "Drawing"; spatialMeshes = SpatialMappingManager.Instance.GetMeshes(); meshCount = spatialMeshes.Count; meshCountDisplay.text = "Meshcount = " + meshCount; SpatialMappingManager.Instance.DrawVisualMeshes = false; //SpatialMappingManager.Instance.enabled = false; //Hopefully this turns off spatial mapping but who knows for (int i = 0; i < meshCount; i++) { totalVerts += spatialMeshes[i].vertexCount; drawMesh(spatialMeshes[i]); } vertCountDisplay.text = "Total Vertexes = " + totalVerts; totalVerts = 0; stopCount = 5; //So this block only gets run once. } } //This draws the meshes I'm capturing from spatial mapping public void drawMesh(Mesh meshIn) { var spatialMesh = new GameObject(); spatialMesh.AddComponent<MeshFilter>(); spatialMesh.AddComponent<MeshRenderer>(); spatialMesh.GetComponent<MeshFilter>().mesh = meshIn; //spatialMesh.GetComponent<MeshFilter>().mesh.RecalculateNormals(); //I dunno if this will do anything useful spatialMesh.GetComponent<Renderer>().material = material; spatialMesh.transform.parent = meshObject.transform; spatialMesh.transform.position = meshObject.transform.position; spatialMesh.transform.localScale = meshObject.transform.localScale; }
Any advice or suggestions are appreciated. Thank you.
