SDK errors while building VS Solution for HoloLens
Hello,
I am getting some build errors while building VS solution for HoloLens. I have created a simple Hello World app for HoloLens and generated C# project from Build Settings.
Below are the errors I am getting when I try to build the solution.
Could not find SDK "WindowsMobile, Version=10.0.17134.0". Assembly-CSharp
Could not find SDK "WindowsIoT, Version=10.0.17134.0". Assembly-CSharp
Could not find SDK "WindowsTeam, Version=10.0.17134.0". Assembly-CSharp
Could not find SDK "WindowsDesktop, Version=10.0.17134.0". Assembly-CSharp
Could not find SDK "WindowsMobile, Version=10.0.17134.0". Origami
To make sure that the issue is not related to my project, I downloaded Origami sample from HoloAcademy and tried creating VS Solution from that. I am getting the same error for that also.
So looks like some issues with my environment. Below are my environment:
- Windows 10 Pro 1803
- VS 2017 Pro 15.7.5
- Unity Pro 2017.4.1f1
I am wondering how does Mobile/IoT/Team SDKs came into HL solution.
Does anyone faces this issue before?
Any help is appreciated.
Thank you.
I've got the same problem, did you solve it ?
The issue was due to corrupted configurations. I finally reinstalled my OS to fix the issue.
I've got the same problem,how did you solve it ?
