its possible to do login authentication using hololens device.
edited August 2018 in General
i need to develop authentication for hololens uwp or unity project which type of authentication is possible,(example,fingerprint,voice recognize,qrcode scanning etc......)
one more doubt its possible to do with hololens and mobile qr code scan authentication and sync all data from hololens to mobile. like watsapp web sync.
  • I don't completely follow your question but you can definitely do QRCode scanning with the Hololens.
    You can not do fingerprint scanning unless you used a 3rd party adapter.
    There is a mic so you may be able to wire up voice recognition but I have never done that before and can't say with certainty the mic would be good enough to tell the difference between voices.
