HOLOLENS (UWP) CONNECTION MYSQL HELP!!!
edited August 2018 in Troubleshooting
Dear Sirs,
I'm trying to connect Hololens (Universal windows platform) to Mysql DB.
I'm using system.data.dll & Mysql.data.dll & connector/Net 6.9.12 for operating sytem .NET & MONO.
Scripting backened IL2CPP, Api compatibility level: .NET 4.x
In Unity connection was right.
In hololens it does not works
Is there any library to connect Mysql to UWP?
If not, can I connect creating new library?
Please HELP :( ... :(
Thanks very much
Regards
  • Pretty sure UWP application run a sandbox and have no access to the servers. You'll have to use WCF or a middle layer of web app. Just off the top of my head, check all the information I've mentioned here.
