Problems trying to implement/build spectator view
Following this tutorial, I get stuck on section of "Building the plugin" and specifically this line:
"Set the build options to Release and x86, then build the solution."
I set the dropdown to Release, the other to x8& press the fine green button, and this happens:
1>------ Build started: Project: SpectatorViewPlugin, Configuration: Release Win32 ------
1>Object reference not set to an instance of an object.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Why? I did all the steps prior, and I installed this to the same directory as the VCPKG as advised.
Also is there any way to make this work with android too? or just iPhone?
