Tap To Place Bug?
Hi everyone. Im running into issues with TapToPlace that I cant seem to figure out.
I attach TapToPlace from the HoloToolkit on my object. When I launch in the emulator everything works as expected. When I launch to the device after placing and moving a couple of times all code after SpatialMappingManager.Instance.DrawVisualMeshes = true; no longer runs. Here is some code I was testing with. Im changing the color of the cube I am using to move things around to see what is happening. The first few times the cube goes back and forth between blue and red as expected but after about the third time the cube goes black and never gets to blue. The Spatial Mapping Manager draws meshes as expected. Am I missing something?
// Copyright (c) Microsoft Corporation. All rights reserved.
// Licensed under the MIT License. See LICENSE in the project root for license information.
using UnityEngine;
namespace HoloToolkit.Unity
/// public partial class TapToPlace : MonoBehaviour { bool placing = false; public GameObject myItem; public GameObject myAudio; // Called by GazeGestureManager when the user performs a tap gesture. void OnSelect() { if (SpatialMappingManager.Instance != null) { // On each tap gesture, toggle whether the user is in placing mode. placing = !placing; // If the user is in placing mode, display the spatial mapping mesh. if (placing) { gameObject.GetComponent<Renderer>().material.color = Color.black; SpatialMappingManager.Instance.DrawVisualMeshes = true; gameObject.GetComponent<Renderer>().material.color = Color.blue; } // If the user is not in placing mode, hide the spatial mapping mesh. else { SpatialMappingManager.Instance.DrawVisualMeshes = false; gameObject.GetComponent<Renderer>().material.color = Color.red; } } else { Debug.Log("TapToPlace requires spatial mapping. Try adding SpatialMapping prefab to project."); } } // Update is called once per frame. void Update() { // If the user is in placing mode, // update the placement to match the user's gaze. if (placing) { // Do a raycast into the world that will only hit the Spatial Mapping mesh. var headPosition = Camera.main.transform.position; var gazeDirection = Camera.main.transform.forward; RaycastHit hitInfo; if (Physics.Raycast(headPosition, gazeDirection, out hitInfo, 30.0f, SpatialMappingManager.Instance.LayerMask)) { // Move this object to where the raycast // hit the Spatial Mapping mesh. // Here is where you might consider adding intelligence // to how the object is placed. For example, consider // placing based on the bottom of the object's // collider so it sits properly on surfaces. this.transform.position = hitInfo.point; // Rotate this object to face the user. Quaternion toQuat = Camera.main.transform.localRotation; toQuat.x = 0; toQuat.z = 0; this.transform.rotation = toQuat; } } } }
OptionsPatrick mod
Yes, I believe there is a bug. I just pushed what I think is the fix. The DrawVisualMeshes property had the potential to access a renderer that had been deleted.
Can you either pull or update UpdateRendering in SpatialMappingManager.cs with:
private void UpdateRendering(bool Enable) { List<MeshRenderer> renderers = Source.GetMeshRenderers(); for (int index = 0; index < renderers.Count; index++) { if (renderers[index] != null) { renderers[index].enabled = Enable; if (Enable) { renderers[index].sharedMaterial = SurfaceMaterial; } } } }
6
@AWarren,
That did the trick! Thanks so much!
Thanks for reporting the issue.
