How to Convert EDB to PST Conversion
InQuit EDB to PST Converter has more than 2 million satisfied customers, they say that this software is very easy to use and it is less time consuming as compared to other migration tools available in the market. This tool can support the various latest version of MS Outlook, MS Window and Exchange Server, this tool will provide you with the results in various different types of formats like EML, MSG and HTML. With the help of this tool, you can also migrate the data to office 365 and Live Exchange Server these are the cloud-based applications. With the help of this tool you can see the preview of the conversion before the actual conversion is done you can also select the destination where you want to save the data. Using this best and advanced tool you can access lost and permanently deleted file along with emails, inbox, sent the item, draft, delete-items, attachment, calendar, notes, task (To, Cc, Bcc, Date, From, Object and Time). This utility is great at work and provides 100% accurate result according to your wishes. This application is compatible with all the version of MS Outlook 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019. You can try the free demo version of this tool and can convert the emails from each folder. If you want to return the software you can also return it within the 30 days and also take your money back. This application supportable with all the version of OS Windows such as 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit). You can ask your quires any time because we have 24x7 customer care services.
Read More Info: https://www.inquitsoftware.com/en/pages/edb-to-pst-converter.html
