Best way to Recover Corrupt OST File and Conversion OST to PST
edited October 2019 in General
Atom TechSoft OST to PST Converter is a professional OST to PST conversion and OST file repair tool from Atom TechSoft Software, a provider of email backup, email migration, and data recovery solutions. The utility software is designed to retrieve and repair damaged and corrupted OST files and able to convert these files to PST and other formats. Conversion is fast and safe with the software able to keep original file integrity including folder hierarchy and file metadata. It can convert large size OST files and transform them into smaller pieces of Outlook PST files. The converter tool supports formats such as PST, MSG, EML, MBOX, ICS, HTML, and VCARD.
    edited October 2019
    Gives Well & Good Solution of Atom TechSoft Team
    If you are looking for the OST to PST Converter for Mac? You can try the Mac OST to PST Converter without any doubt. It's compatible with Microsoft Outlook 2019, 2016, 2013, 2010, 2007, and 2003. The Mac OST to PST can easily run on Mac 10.10, 10.11, 10.12, 10.13. The OST to PST Converter tool for Mac is very easy to use, you have to just follow 3-4 steps and its easily migrate, configure, and filter you're all files and install at the desired location.
    Visit here:- https://www.toolscrunch.com/mac-ost-to-pst-converter.html
