Using Bluetooth devices with Holo
Hello,
I am trying to figure out if apps can use paired Bluetooth enabled devices that support GATT profile(s). From documentation it looks like pairing devices with HID/GATT profiles is supported but there are limitations.
I am thinking about devices without audio/file transfer capabilities such as heart rate and blood pressure monitors, thermometers, battery services, etc.. Will those devices pair to Holo and be accessible from UWP app?
AlexG ✭
@Brandon said:
Devices with HID/GATT profiles can be paired. For devices that have specific capabilities, like pedometers, it would need a specific app to make sense of the Bluetooth accessories inputs. You can test this with any Windows 10 device too -- Phone and tablets will behave the same way.Brandon, let me verify that I've got you correct - if I have GATT device that works with my Win10 UWP app, it will work with Holo as well (same app or most probably different app using same code)?
@AlexG, yes that is the expectation.
Great!
