Color Square appears with Hololens emulator using Parallels 11 for Mac
After the emulator opens up with the nested hyper v enabled, 8 gig's set aside, and 4 processors, it works fine for a little while, but for some reason a square colored cube appears in place of the Hololens store browser, or any browsers.
Any suggestions?
DavidKlineMS mod
Did you build and deploy the template application from Visual Studio? That's what appears to be running in your emulator.
@timg Yes, I've basically followed the steps in this video. Was I not suppose to use the template from Visual Studio?
Here are some of the outPuts right before the square appears:
The thread 0xb84 has exited with code 0 (0x0).
The thread 0xc90 has exited with code 0 (0x0).
The thread 0xa40 has exited with code 0 (0x0).
The thread 0xd70 has exited with code 0 (0x0).
Also, here's the specs from the MacBookPro used; I'm pretty sure I met the system requirements.
@AR123,
Since you started the emulator by launching the template application, this is to be expected as the emulator is running the application that has been launched.
Please see the steps here or here to close your application and return to the shell.
David
