Network Connection via USB connection
How does the network connection work when the Hololens is connected to the PC via USB?
In Visual Studio, the network ip address to run on remote machine is "127.0.0.1", which is localhost - the loopback address for the PC.
Here's what I want to do: Open a TCP Client connection inside a Hololens app to talk to a TCP Server running on the PC, all through USB.
I have the exact same scenario working over Wifi no problem - I'm just not sure what IP address the Hololens should use to talk to the PC over USB.
Any ideas?
Jason
