Need help with object tracking.
Hello guys,
I am very new to the Microsoft HoloLens community and programming in general. But I am willing to learn. My school recently bought a set of the HoloLens, and we are supposed to develop an app or of sort that detects object in a degraded visual environment. So I was hoping someone would be able to give me a basis on how I can approach this project. Based on my knowledge we can use the object detecting entities on the HoloLens, so far that's all I know. I would really appreciate some help.
Thanks
Vamshi Chittaluri
    @CurvSurf said:
    @vamshi_chittaluri94
    Object detection (and/or recognition, measurement) in a degraded visual environment is absolutely impossible at the moment!
    Even if we are armored in HW/SW technologies including 3-D cameras, mathematics, statistics, computer vision, robotics, we will be short on brains in timescale terms of at least 3~5 years.
    Hey CurvSurf,
    Thanks for the input, I really appreciate it! Is there any way we can connect external sensors to the HoloLens. For example, object detection based on sensors that are connected to a body and they transmit the readings onto the HoloLens. Suppose I as a body am contained in a sphere, and I have multiple sensors attached to me that would map a sphere, and the HoloLens would present readings from the sensors that would show a close obstacle in my close vicinity on the sphere, with me being in the center.
    Thanks
    Vamshi Chittaluri
    CurvSurfCurvSurf ✭✭
    edited October 2016
    Visual sensing inside a spherical spatial environment is hell on computer vision or photogrammetry because of the parameter singularity. There will be no diffenrence of object distances, when you are in the center of the sphere. It will be more terrible if there is no distinct features, e.g. non-periodical textures.
    I correct above comments of:
    • 'spherical' to 'cylindrical'
    • 'in the center of the sphere' to 'on the axis of the cylinder'.
    In photogrammetry, 'danger cylinder' is well known.
    @CurvSurf
    Thanks, Is there a guide or something where I can follow for basic obstacle detection using the HoloLens? If I can aclamatize myself to the basics, I will explore further options available to me in this domain.
    Thanks
    Vamshi
    With 'basic' obstacle detection, any triangles of spatial mapping could be obstacle.
    How a virtual character can avoid obstacles is the problem.
