hololens tethered to power
I know the hololens is a standalone device but... Can it be used while plugged in to a power source to extend the usage?
    Thanks for the info... Especially the part about optimal distance. I had seen that in the docs but did not think about some practical constraints that might impose on a sitting user.
    What about a USB battery style charger like the ones people use to recharge their phones on the go?
    Many of them are of a size that will fit in a pocket. Once our devices come in, I was planning on testing sticking one of them in a pocket with a USB cable connecting it to the HoloLens to see if it would continue to charge the HoloLens while in use..
    That should work but I wont be the first to try it. I am too concerned about something frying my HoloLens...
