GalaxyExplorer crash when running on device
ccifraccifra
edited April 2016 in Questions And Answers
I am new to this but I was hoping to get off to a good start by playing with the galaxy explorer. Unfortunately it crashes just after I place the earth on screen and see the solar system. I get an AccessViolation here:
    Collider[] colliders = content.GetComponentsInChildren<Collider>(true);
    foreach (Collider collider in colliders)
In TransitionManager.cs line 505.
And the output window shows:
ViewLoader: Loaded SolarSystemView
(Filename: C:\buildslave\unity\build\artifacts/generated/Metro/runtime/UnityEngineDebugBindings.gen.cpp Line: 45)
ViewLoader: Loaded GalaxyView
Supplied PxGeometry is not valid. Shape creation method returns NULL.
(Filename: C:/buildslave/physx/build/Source/PhysX/src/NpFactory.cpp Line: 675)
Exception thrown: 'System.AccessViolationException' in UnityEngineProxy.dll
The program '[2872] GalaxyExplorer.exe' has exited with code -1 (0xffffffff).
Any idea what could be wrong? I am using VS 2015 Update 2 and Unity 5.4.0b10-HTP
  • Fails same way in HoloLens Emulator when built in Debug x86 Stops at same line number. This runs in the Unity player
    edited April 2016
    Have you tried to use a release deployment onto the device then go into the portal and start the deployment from the app section of the portal. This is probably how developers did not see this problems especially as the program runs on Unity player
