Tap and Drag to Place
I'm looking for a way to implement a "Tap and Drag to place".
It's like TapToPlace but instead of using gaze, i want to use the movements of my hand.
now, I was watching the 211 academy and somehow there is a way in there.
I saw that they used the voice input, then got to PerformManipulationStart then PerformManipulationUpdate where they place the astronaut according to the position of the hand.
Can you guys tell me if I can use that with a simple OnSelect and if it can be used with the spatial mapping to place objects.
  • Hi Angelica,
    Yep. That'll work. You'll want to add a GestureManipulation script to the objects you want to move and only enable an object's GM when it has focus and gets tapped. Then disable the GestureManipulator again on the second tap. The GM's update method will look something like this:
        void Update()
            if (hasFocus && Manipulating)
                Vector3 localHandPosition = Camera.main.transform.InverseTransformPoint(GestureManager.Instance.ManipulationHandPosition);
                Vector3 initialHandToCurrentHand = localHandPosition - initialHandPosition;
                Vector3 scaledLocalHandPositionDelta = Vector3.Scale(initialHandToCurrentHand, handPositionScale);
                Vector3 localObjectPosition = initialObjectPosition + scaledLocalHandPositionDelta;
                Vector3 worldObjectPosition = Camera.main.transform.TransformPoint(localObjectPosition);
                if (targetInterpolator != null)
                    targetInterpolator.SetTargetPosition(worldObjectPosition);
                else
                    transform.position = worldObjectPosition;
  • edited November 2016
    @james_ashley said:
    Hi Angelica,
        void Update()
                else
    can I ask you to be more specific?
    in my mind, i write the Gesture manipulation(i saw that there is one,very similar to your suggestion, from the HoloToolKit) then have a Cube manipulator script where i write in the OnSelect method the piece of code from the 211 tutorial(the one the moves the astronaut)
    I hope you can provide a little step by step since i'm making my project from zero and everything seems to be confusing. :smile:
    @james_ashley. i was able to make a cube move. the truth i only replaced the astroman with a cube. somehow the moving works!
    i now only have to add a spatial mapping and solve the range of movement. as for now, the object moves slower than the hand itself and it if left behind. annoying.
    i hope I can figure out how to make things work. :)
    evry suggestion is well accepted.
    Vector3 moveVector = Vector3.zero;
            // 4.a: Calculate the moveVector as position - manipulationPreviousPosition.
            moveVector = position - manipulationPreviousPosition;
            // 4.a: Update the manipulationPreviousPosition with the current position.
            manipulationPreviousPosition = position;
            // 4.a: Increment this transform's position by the moveVector.
            transform.position += moveVector;
    this the piece of code used tomove the object.
    this is very slow, so I was wondering if I can multiply moveVector to a sort of movement sensibility to make movement faster.
    i know that this piece is executed frame frame.
  • @angelicaHolo,
    If you take a look at the GestureManipulator behaviour that comes with the HoloToolkit, there's a config setting at the top to set the sensitivity. You can up these values to make the movements more sensitive:
        [Tooltip("How much to scale each axis of hand movement (camera relative) when manipulating the object")]
        public Vector3 handPositionScale = new Vector3(2.0f, 2.0f, 4.0f);  // Default tuning values, expected to be modified per application
    James
