Tap To Place Script Not working
I'm attempting to get the HoloToolKit TapToPlace script working.
My scene has a box with tap to place script on a cube and a basic cursor.
I also have an empty game object Called Managers with GesturManager, GazeManager, and WorldAnchorManager attached.
Spacial Mapping is in the root of the scene.
What else could be going wrong. I can see my box but i'm unable to tap it and move it.
OptionsHoloSheep mod
You may also want to test with the box starting at an initial position closer to you (in the same room) to narrow down if your issue is with TapToPlace or if it is related to your object being behind the spatial map.
@JD_Holo_Dev
is the SpatialPerception capability enabled?
Edit -> Project Settings -> Player, and under the Windows Store section, in the Publish Settings enable the SpatialPerception capability
Alternatively, have you tried putting a Debug.log statement into the different routines like TapToPlace, GestureManager, GazeManager to see which routines and lines are being executed?
yes the spatial Perception is checked. When the app starts up i can see my box then spatial mapping meshes start and my box is hidden in the other room behind walls. if i turn off the mesh I still cant seem to tap on the box it still seems behind a wall.
I havent tried debug logs yet. Ill try and report back.
@JD_Holo_Dev
I added the debugs to the scripts in various places. Things just magically started working. Not sure what I did though. Its working though with multiple objects around the scene.
Thanks for your help.
