Holotoolkit Input Module Holding, manipulation and navigation events not working
Hello everyone,
I was looking into the new Holotoolkit input system which came with unity 5.5 and I was happy to see how easy to use it is.
Everything works find when I want to implement some input interfaces such as IInputClickHandler, IInputHandler, IFocusable.. for instance.
However I can't figure out how to use the following events : Hold, Manipulation, Navigation. Even In the "Input test scene" of the Holotoolkit, the Debug.LogFormat are not working for them.
Someone could advice me about the proper way to use it ?
Thank you,
Vincent
@vincent,
Definitely take a look at the HandDraggable script, which handles manipulations and implements most of those interfaces. It should guide you through how to best do the more complicated interactions. IInputClickHandler is really easy, by the way. Basically you need to drop an InputManager prefab and a cursor into your scene. Then when your gaze falls on an object that has an IInputClickHandler implementing behavior on it, IInputClick will get called.
I concur with @james_ashley. I was able to implement all of the different interfaces without any issue just on my own.
Jesus I have exact same problem! Did you fix it?
-> I found it, In the Unity Game Window, EditorHandsInput.cs Can't make Hold or manipulation events. So build on Hololens. you can see results
can you guys tell me where to get the hand's position?
I tried
Camera.main.transform.position + new Vector3(0, -0.2f, 0) - Camera.main.transform.forward * 0.2f
from the hand draggable script...but is it right?
