Hololens Emulator running on W10 running on VMware Workstation Player 12
Is there a way to make the Hololens Emulator running on W10 running on VMware Workstation Player 12
I'm not 100% sure if this will work, however you could theoretically.
You'd first have to merge the two differencing disks (VHD's) together (
"C:\Program Files (x86)\Windows Kits\10\Emulation\HoloLens\10.0.11082.1039\flash.vhd" and "C:\Users\[username]\AppData\Local\Microsoft\XDE\10.0.11082.1039\dd.1268x720.2048.vhd" ) and then convert it to a vmdk file. Next you'd have to configure VMWare to use the same settings: /Video 1268x720 /Ram 2GB
You'd loose the Xaml XDE rendering UI, and the XDE Tools that give you the input capabilities, rotations, Device portal, monitoring and etc, but you'd theoretically have a functioning image you could deploy to.
Dwight Goins
http://dgoins.wordpress.com
Using VMWare Fusion 8.1.1, I was able to set the OS type to Hyper-V, enable support within Windows, and successfully run the HoloLens Emulator inside the VM. Here are the full instructions.
