How does hololens define the plane surface and wall of the worldspace
I am looking to the Microsoft HoloLens: Course 230 - Spatial Mapping - Ch. 3 - Visualization
(https://www.youtube.com/watch?v=RnkvXl-aXD4&t=241s)
This chapter of the course is about how to apply the shaders the room model, and I can understand if the surface is normal to a plane, then it should the wall. But how does the hololens recognize that a plane is a ground surface of the room?
This is a basic 3D geometry and linear math question you're asking. Typically the surface normal is the vector that points back towards the camera when the camera is pointed at the surface. The World+View+Projection (WVP) matrix contains floats that have projections in world space, + view space + camera space. In each of these floats there is an "UP" vector that tells the shader which way is up. Thus what ever is considered as "UP" the opposite of that is down aka the floor.
In the example above the pixel (VertToFrag) shader is being passed in a vectors for View, Surface Normals, and World. Using linear math as long as you have at least 2 axis (in this case vectors) that are perpendicular to each other, and you've chosen an handedness (Right hand or Left hand) you can always determine the "UP" vector by just multiplying.
However you'll notice Unity supplies the UP vector already in the MVP (model view project) matrix in the vertex shader (UNITY_MATRIX_MVP).
Dwight Goins
http://dgoins.wordpress.com6
Dwight Goins
Thanks man, you rock!
