Hololens in Camera (Resolution Differences when Taking a Photo and Using Unity's Camera GameObject)
I'm trying to use the Hololens camera to take a photo, run an OCR on the photo, and then place tags in world space based on the pixel coordinates I get from the OCR. However, I find that the world coordinates are little bit off because of the different image resolutions I'm using.
When I take a photo using the Hololens camera, I take the photo in 2048x1152. I send this to the OCR and get back pixel coordinates. During this time, I position a second camera (not the main camera) to where I took the picture. Then, I raycast from this camera using Unity's Camera.ScreenPointToRay function. However, the Unity camera is 1280x720. Even if I scale the pixel coordinates from the 2048x1152 resolution to the 1280x720 resolution, the tags are still off in world space. It seems like the Hololens is cropping the photo instead of scaling since nothing can be raycasted outside the 1280x720 resolution. I think this is the issue because when I take the photo in 1280x720, everything shows up correctly. However, I'd like to make the field of view bigger so using 2048x1152 would be ideal.
Unfortunately, Unity cameras have read-only pixel width and height so I can't change the resolution. I tried to do Screen.SetResolution(2048, 1152, false) but that didn't work so well. I look at https://developer.microsoft.com/en-us/windows/holographic/locatable_camera, but didn't find much on changing the resolution of the Unity camera.
Has anyone encountered this problem or have suggestions? Thanks!
    AmerAmerAmerAmer ✭✭✭
    edited February 2017
    Its the lense. I haven't gotten higher than 720p on video and I believe image as well. You might have to scale the resulting image before you process it. I remember talking to Unity editor/engine developers about the LocatableCamera and they had a bunch of bugs in the pipeline to fix but that was during their 5.5 early beta. They might have fixed it by now.
    1280x720 45deg (default mode)
    2048x1152 67deg Highest resolution still image
    896x504 896x504 896x504 48deg Low power / Low resolution mode for image processing tasks
    Hi jonathanhuang,
    i'm developing an app similar the your. I had the same your problem and understand that it can't be solved because it's not possible to raycast outside the 1280x720.
    You said that using the 1280x720 resolution all works fine, but not for me. Let explain.
    In my case I'm talking about the object detection and not OCR, so the hololens wait for 4 coordinates for each bounding box.
    Step:
    1) Take the picture
    2) Send to a server for elaboration
    3) Receive the 4 coordinate
    4) Evaluate the center of the bounding boxes
    5) Raycast the center
    What happen is that for the object that are in the center of the image it works fine. So the ray is casted correctly in the center of the bounding box, but for the object that are on the right or on the left, the raycasting is off. In particular the ray are casted slightly towards the center.
    For understanding:
    • if an object is on the left, the ray is casted slightly further to the right
    • if an object is on the right, the ray is casted slightly further to the left
    The same for top and bottom.
    Can you help me to explain this behavior?
    Thanks a lot.
    Ciro Varriale
    XyyXyy
    edited April 2018
    Hello.Can I ask you the solution to do object detection? Do you use OpenCV ? or something else? Can you give me some detail? Thank you!
    Hey,VarrialeCiro@VarrialeCiro
    what does these "4 coordinates" you mentioned above refer to ?
