Unity Solution to VS 2015 Comm issue with runtimes
I've been having difficulty getting all the developer software setup.
I installed unity for hololens and the other required software.
I had multiple copies of visual studio on my computer such as 2012, 2015 desktop and 2015 community. I removed 2012 and reinstalled community making sure to include the necessary files as outlined in the documentation.
At present, when I attempt to load a unity solution in VS 2015 Community I get the following warning:
Warning Your project.json doesn't list 'win10-arm' as a targeted runtime. You should add '"win10-arm": { }' inside your "runtimes" section in your project.json, and then re-run NuGet restore. Hololens3DModels
In the project.json file, I clearly have these defined:
"runtimes": {
"win10-arm": {},
"win10-arm-aot": {},
"win10-x86": {},
"win10-x86-aot": {},
"win10-x64": {},
"win10-x64-aot": {}
Any suggestions?
After looking though several online forums I was able to progress to the following problem after going to project -> manage NuGet and downloading the latest versions. But I'm stuck with a solution explorer that shows 3 projects called:
Assembly-CSharp ( Universal Windows)
Assembly-CSharp-firstPass (Universal Windows)
and finally in bold:
Hololens3DModels (Universal Windows)
When I attempt to run on the remote machine (hololens) I get:
Error The command ""E:\Youtube\Hololens\Hololens Projects\Hololens3DModels\App\Unity\Tools\SerializationWeaver\SerializationWeaver.exe" "E:\Youtube\Hololens\Hololens Projects\Hololens3DModels\UWP\Assembly-CSharp-firstpass\bin\x86\Master\Unprocessed\Assembly-CSharp-firstpass.dll" -pdb -verbose -unity-engine="E:\Youtube\Hololens\Hololens Projects\Hololens3DModels\App\Hololens3DModels\Unprocessed\UnityEngine.dll" -unity-networking=E:\Youtube\Hololens\Hololens Projects\Hololens3DModels\App\Hololens3DModels\Unprocessed\UnityEngine.Networking.dll "E:\Youtube\Hololens\Hololens Projects\Hololens3DModels\UWP\Assembly-CSharp-firstpass\obj\x86\Master\x86\Master"" exited with code 1. Assembly-CSharp-firstpass E:\Youtube\Hololens\Hololens Projects\Hololens3DModels\UWP\Assembly-CSharp-firstpass\Assembly-CSharp-firstpass.csproj 180
Error Metadata file 'E:\Youtube\Hololens\Hololens Projects\Hololens3DModels\UWP\Assembly-CSharp-firstpass\bin\x86\Master\Assembly-CSharp-firstpass.dll' could not be found Assembly-CSharp E:\Youtube\Hololens\Hololens Projects\Hololens3DModels\UWP\Assembly-CSharp\CSC
Error Metadata file 'E:\Youtube\Hololens\Hololens Projects\Hololens3DModels\UWP\Assembly-CSharp\bin\x86\Master\Assembly-CSharp.dll' could not be found Hololens3DModels E:\Youtube\Hololens\Hololens Projects\Hololens3DModels\App\Hololens3DModels\CSC
Error Metadata file 'E:\Youtube\Hololens\Hololens Projects\Hololens3DModels\UWP\Assembly-CSharp-firstpass\bin\x86\Master\Assembly-CSharp-firstpass.dll' could not be found Hololens3DModels E:\Youtube\Hololens\Hololens Projects\Hololens3DModels\App\Hololens3DModels\CSC
Any thoughts on this first pass issue?
Thank you,
George
Hi George,
Did you install the UWP runtime from http://unity3d.com/pages/windows/hololens
Also your target in VS should be x86 and not ARM. Can you try switching that and see if that helps?
Bharat
