Spectator view does not work?
Hello,
i followed this tutorial (https://developer.microsoft.com/en-us/windows/holographic/spectator_view), SharingService is working and receive from hololens, Console log in unity notify me that hololens is connected.
I can not get the final result, i see in the spectator view compositor what my editor's camera see, but not from the point of view of my hololens camera.
What could it be?
I tried also the SharedHolograms sample, same problem.
Thanks in advance for your answers.
EDIT:
It seems that one of the compositor is not the point of view of unity's camera.
In addition, spectator view manager creates an additional camera. Is this the problem?
    On your SpectatorViewManager prefab, are you setting the "Spectator View IP" field to the IP of the HoloLens on your spectator view rig?
    The Unity camera that is created on HolographicCameraManager will become a child of the remote player object that has the same IP as "Spectator View IP".
    When that HoloLens joins the sharing session, it will create a remote player as a child of the anchor. Click on the anchor in Unity and move your HoloLens devices around, you should see green wireframe cubes moving around in the Unity editor, corresponding to each HoloLens in the session.
    I'm having the issue that nothing is shown in the Hierarchy view.
    I built the compositor in x86 and x64.
    I'm trying to use the SharedHolograms sample, but can't set the IPs as I can't see the SpectatorViewManager.
    Any idea?
    Help?
    @Pedro said:
    Help?
    Hey Pedro
    Did you fix it? Cause im meeting the same issue
    @Pedro It looks like you've opened the sample project, but not the "Sharing" scene. Just open the unity scene and you should see everything in the hierarchy panel.
    Also, use the same unity version! I tried opening the project in a newer version, which destroyed everything.
    Jimbohalo10Jimbohalo10 ✭✭✭
    Painfully found you must use RELEASE build not Debug!!
