Wireless Ring Barcode Scanner HoloLens Bluetooth Integration.
New Hardware Integration for HoloLens:
MT500L Wireless Ring Scanner for retail, logistics, distribution and warehouse management markets:
See:
Hands-Free Scanning Design
MT500L’s strap design and dual touch button allows workers to wear the scanner comfortably on either their right or left hand. The touch button reduces working interference and increases workers satisfaction and efficiency. Its compact and minimized form factor also makes it a great tool to wear for over 8 hours.
On-Screen Barcode Readability
The MT500L SBR (Screen Barcode Readable) laser scanner is equipped with a thin, sharp, class 1 laser aimer which helps users to accurately aim at barcodes. With the latest improved decode algorithm, MT500L not only ensures accurate barcode capture from low contrast to on-screen barcodes, but also provides consistent performance in both indoor and outdoor lighting conditions. Mobile point of sale and e-coupon application can therefore be accomplished with MT500L’s on-screen barcode readability.
User-Friendly Design with HID interface
The HID interface of wireless technology adopted by MT500L wireless ring barcode scanner makes integration of barcode scanning into mobile devices easier than before. All it takes is simply few seconds of wireless pairing with user’s mobile device and the MT500L will work with all existing apps on Android or iOS devices.
Full Shift Battery Life
MT500L wireless ring barcode scanner saves more battery life and provide extended period of operation by adopting auto-adaptive illumination method, which keeps the illumination off in most of the cases and turns on only when it is needed in poor ambient light conditions.
Snappy and Accurate Scanning
The fast-pulse illumination and fast sensor shutter speed enable MT500L to decode barcode at a full 400 scans per second, delivering outstanding motion tolerance, ensuring workers who are constantly on the move to capture any barcode easily.
Reliable Data Security
Based on standard, the wireless uses AES 128-bit encryption to protect user’s data and utilizes 24-bit CRC calculation to prevent any interference when data is being transmitted from MT500L to the mobile host device.
Also See:
http://www.marson.com.tw/webe/html/product/show.php?num=115&kind=67
Thank you.
Jaswinder Brar.
