Battery life on charge and with power bank
Hello,
I work on an industrial project.
I need that my hololens to work all the day long on my application. It will be on charge all day long too.
I want to know how much time hololens can work on charge. Because hololens discharges faster than it loads.
And i saw on this : https://lockerdome.com/7046634060127041/8520008968060692
with a power bank Hololens had an infinite battery life.
Is that true?
Thanks for yours answers.
I connect my Hololens to a portable charger when I need more than 3 hours. As you have pointed out the amperage is low on most portable chargers so the power supplied does not keep up with the demand (i.e. the battery % still goes down. ). I haven't worked out exactly how long the battery will last but my estimate is 6 hours
As I noted here:
https://forums.hololens.com/discussion/807/hololens-first-impression
The powerbank needs a QC 3.0 output port to act as a charger for the Hololens. Anything less and the Hololens drains faster than it charges.
Will this power bank work for Hololens...?
