Some features that work in Unity Engine (runtime) don't work in Hololens
Hi all,
Case 1;
Some UI components like Slider from Unity does not move in HoloLens using Gaze and gesture. (They work just fine in Unity Editor)
Did you face any similar UI related inconsistencies?
Case 2:
I am developing a tool that will download 3D objects at runtime from my web server and show it on HoloLens.
I am making HoloLens and the webserver talk through the REST APIs which is working fine.
The response is a JSON and I am using UnityEngine.JsonUtility to parse it.
JsonUtility is working fine in my Unity Editor, but when I am deploying app on HoloLens, it's returning null.
Usage:
accountDir = JsonUtility.FromJson<DirOrFiles>(wwwDir.downloadHandler.text);
(Class DirOrFiles has one array of string object: contents)
Here accountDir.contents is null and hence my code cannot move forward.
or do you recommend any other JSON parser class?
Thank you in advance.
Arjun
    I've used SimpleJson without issue.
    http://answers.unity3d.com/questions/987666/how-can-i-import-simplejsoncs-to-unity.html
    I haven't had any issues gesture inconsistencies. How are you faking the gesture in the engine?
    Hey @mark_grossnickle
    I will try and use the SimpleJson today. Did you ever try JsonUtility?
    I am using HoloToolkit's input manager for the gestures and I fake it by holding up key and a click, that's like an airtap.
    I was not able to slide the slider. There are certain parts of unity that are triggered for Mouse Events(like hover, button up/down) but they do not trigger for the Gaze/Gesture. (at least for me)
    Arjun
    No, I haven't used jsonUtility.
    And now I understand. Mouse interactions don't automatically get ported into Hololens. As far as I know.
    To do the slider you would need to implement the navigation gesture and wire it to the slider.
    Here is a general gestures tutorial:
    https://developer.microsoft.com/en-us/windows/mixed-reality/holograms_211
    edited May 2017
    Arjun,
    Here is an old post around using Unity UI for the HoloLens but it may be beneficial for you:
    https://forum.unity3d.com/threads/unity-ui-on-the-hololens.394629/
    Take a look at the InputManager test site in the HoloToolkit to actually interact with the slider control. I've not tried to work with that particular control. In general, if you can get it to work with the InputManager prefab in the editor by using the hand / air tap it should work for you in the emulator or on the device itself.
    Thanks for being a member over at https://LearnHoloLens.com. I'll also mention to take a look at the Gaze and Gesture master class as I go into detail about the InputManager.
    Regarding JSON -- make sure that you have selected the Internet client capability so the device can actually reach the outside world. It could be that is the real issue.
    Hope that helps,
    Chad
    Thank you for the UI help.
    Chad, I have the Internet Client capability selected. The problem is in parsing the JSON that I get from UnityWebRequest. The request is going through.
    This line of code is returning NULL into the variable accoundDir when ran in HoloLens emulator or on HoloLens.
    It works just fine in Unity, Am I missing something that needs to be done in VS?
    For Unity projects you need to have things in the plugins folder for it to work. So grab the the nuget package from a regular project (like a console project) and then copy the dll into the /Assets/plugins folder in Unity. Then you should have access to it.
    Here is some more info with different tips from others if that doesn't solve your problem:
    http://stackoverflow.com/questions/30398407/adding-json-net-to-a-unity3d-project
