How can I make/build a "Sonorous wall" with Spatial mapping?
I am running an experiment. It consist in adding sound to spatial mapping. The idea is to make a "sonorous wall" as the surfaces are added to spatial mapping render. At the end we will be able to "hear" where the wall is located. I know that the limitation are 10 spatial sounds at the same time. Any idea ? Any code to add to Holokit standard code to make this available?
Thanks!!
I assume you can use the ObjectSurfaceObserver script (i suggest to make a copy of it and replace the original ObjectSurfaceObserver script from SpatialMappingPrefab with your copy) which you can find on the SpatialMappingPrefab, and there is a method called CreateSurfaceObject which as i can see is responsible for creating and returning each surface. You can set your audio to the surfaceObject when it's being created there just before returning it.
I would use the raycast to hit the spatial mapped wall and place a sound on the hit object location. You can also edit the spatial mapping script to add sounds on the mapped object position.
" You can also edit the spatial mapping script to add sounds on the mapped object position. " Where? can you propose me a place inthe script where to do it? Thanks
