Motion controller problems with preview build 16251 ?
When i updated to 16251, The controller is stuck in an infinite reboot. It seems it is a knowing issue which described in https://developer.microsoft.com/en-us/windows/mixed-reality/motion_controllers. I tried to do the device recovery, However it seems dose't work.Is there a problem of this version of windows?
Jesse_McCulloch admin
You are one of the few with a set of motion controllers. I would suggest emailing the [email protected] on this one, you will likely have better luck.
