Acer Mixed Reality - USB Problems on a Surface Pro (2017)
I am running the fall creators inisder 16257.1 on a 2017 Surface Pro, i7, 16gb of ram.
When I plug in the Acer Mixed Reality Headset, I get two USB errors in the device manager. The first is "Unknown USB Device (Device Descriptor Request Failed)" and "Unknown USB Device (Set Address Failed)"; both error 43.
Curious if anyone has gotten the Acer unit working on a 2017 Surface Pro. Any help would be appreciated.
    SunsetSunset
    edited August 2017
    Here is the link link2 that discusses immersive headset support for Surface product line with answer from admin.
    I have surface pro, and not a surface book. The new Surface pro is supported.
    I have the same issue, did you ever find a solution?
    No I didnt. I did have someone test it on their machine and it worked fine. I wish someone at MS could chime in on this issue. I hate having a $299 paperweight.
    Please ensure plugging in the headset, and then File Feedback and share the URL.
    BTW, the minimum hardware spec for development is higher than Surface Pro spec.
    I just tried with the new 16273 release and even with the new USB drivers, the problem of Unknown USB Device error still exists with my Surface Book. I have both the Acer and HP headsets and neither works. And, they both work on my Alienware X51R2 desktop so the headsets are definitely not defective.
    Still not fixed in 16278 build
