Best Shader to display images using the HTK and Unity
Hello,
I want to display images inside my application. So far I apply the image as a texture to a material. The material uses the "StandardFast"-Shader from the HTK. Unfortunatley the image ist quite dark and therefore it appears very transparent. Does someone knows a better shader to display images? Or maybe another trick?
Thanks in advance.
mark_grossnickle ✭✭✭
Are you using lights? If not, just Unlit->Texture is probably your best bet.
