Tap to Place Sharing
I had tried to using the "UNetSharedHologram.CS" which is coming from the Spectator View sample.But there is a problem. In the server you can tap and place the model at where you want ,the client also can see where it is . On the contrary the client tap and place the model, the server has no reaction. I want using this scripts for my project, how can I deal with it ?
Hello, angler!
You can check Holographic Academy and visit
240
chapter:This one should make sense to you (under that link is enough documentation which can help you to find out how it works):
OK, I will have a try!
