Unity virtual reality input problem.
Hi!
I've built two applications one with XR Settings -> Virtual Reality Supported toggle enabled and one without.
When I'm testing the one with the toggle enabled but without mixed reality headset connected, I'm not able to interact with Unity UI and have no input from mouse.
When I'm testing the one without the toggle enabled Unity UI and mouse works just fine.
I want this application to work both on Windows PC and Mixed Reality Headsets, is there any solution to this problem?
What Unity version are you using? I've had some problems using versions after 2017.1
CEO UniVRsitas
I'm using Unity 2017.2.0f3, so it can be the problem.
