HoloTool kit not working with errors
Hey guys,
I have followed every procedure of downloading the holotoolkit folder from github and or the MixedRealityToolKit - Unity - Master, then dragging and dropping the folders I need to import holotool kit into unity
So after I drag and drop the required folders or folder (have tried many variations) I try to build but I get this error
'Assets\HoloToolkit\Input\Scripts\Utilities\Extensions\InteractionSourceExtensions.cs(12,23): error CS0234: The type or namespace name 'Haptics' does not exist in the namespace 'Windows.Devices' (are you missing an assembly reference?)'
I followed this tutorial
https://hololens.reality.news/how-to/hololens-dev-101-build-basic-hololens-app-minutes-0175021/
As instructed, I select everything but the holotoolkit examples and when I build it doesn't work. I try the whole folder, still nothing. Also in the online tutorial a new window tab is created called 'HoloTool Kit' but mine is 'Mixed Reality Toolkit' so I am guessing the tutorial is old? But it should still build and work
I have the latest version of Unity... which folders do I drag and drop to the assets, please help
You need to install and target the latest SDK which is 10.0.16... https://developer.microsoft.com/en-US/windows/downloads/windows-10-sdk
you can first use Windows Mixed Reality PC Check app form Microsoft Store to check your PC,second,you should download vs2017 for developing Mixed Reality develop with the latest version of MRTK.
Guys here is how I fixed my issue.
1. Installed unity Unity 2017.2.1f1 (64-bit)
2. Updated Win10 SDk from here https://developer.microsoft.com/en-US/windows/downloads/windows-10-sdk
3. Visual studio 2017 edition
This should solve the issue.
Guys here is how I solved the issue.
1. Installed Windows 10 SDK from here https://developer.microsoft.com/en-US/windows/downloads/windows-10-sdk
2. Installed Unity 2017.2.1f1 (64-bit)
3. Updated to Visual studio 2017 edition
