Air tap is not working with spatial understanding
I am trying to explode an object by tap gesture. Its working without implementing spatial understanding. the below is what i did,
private void GestureRecognizer_TappedEvent(InteractionSourceKind source, int tapCount, Ray headRay)
if (_objectInFocus == null)
return;
_objectInFocus.SendMessage("DoExplode");
i handled ‘DoExplode’ event in another c# script. Its working fine without spatial understanding. Can anyone help me to figure out?
@AravindSiva,
It depends on what you are doing with Spatial Understanding. The only thing I can see happening is if you are adding planes between you and the object, which might block it. Alternatively, maybe your Spatial Understanding code is failing somewhere, or not completing, and that's why the tap isn't registering? Have you added a remote debugger to determine if your tapped event is being called and if your spat understanding code is completing correctly?
James
@james_ashley,
Thanks for the response. Spatial understanding is working fine and it can successfully scan the room. I have checked with break points in tap gesture function. But it was not getting called at the same time gaze is working fine, so nothing is blocking between me and the Object. If I remove the spatial understanding prefab, tap gesture is working. Can't figure out what is the problem.!
Not sure if it'll solve the problem, but you could try implementing the IInputHandler interface from the HoloToolKit possibly? And do the same thing you are doing here inside of the OnInputDown/OnInputUp methods instead.
AR Developer
