Holograms Deployment Failure when choosing "Remote Machine"
My program runs successful in emulator. When I try to connect to real device and choose "Remote Machine" in VS 2015, I get not get rid of this bug:
I am under developer mode and turn off all firewalls.
When I transfer to "Device", it works successfully.
Any idea about hot to fix this under "Remote Machine"?
ahillier mod
Hi @RosieLiu,
Whenever I hit strange errors like this, the best solution I've found is to close VS, delete my build folder, and then rebuild my project in Unity. This will generate a fresh solution for VS, so you will need to reset you build target and IP Address for your HoloLens. If you have successfully paired your HoloLens to your PC, then you should be able to deploy via 'Remote Machine' with the fresh solution.5
Hi @RosieLiu,
Thanks! I fix it by choosing "Device" instead of "Remote Machine".
