WMR : Unused Resources and lock FPS
I just received my Acer Headset today and when I got it plugged everything is sluggish.
Here avec my Specs:
ASUS R9 280X (3GB)
AMD Ryzen 5 1600
16gb RAM
Using a Display Port to HDMI2.0 adapter.
After trying to debug it for a few hours, I got to the device portal and looked at my Frame Rate and it's at a constant 8.6fps. Meanwhile my GPU and CPU are under 10% utilisation.
What is causing this issue and how can I fix it?
Thank you,
Patrick J.
Have you tried update your Graphics Card's driver to the latest?
