Hololens Audio Input/Output
Does the Hololens come with a mic input and audio output?
DavidKlineMS mod
@AR123,
Yes, HoloLens has four microphones, a set of speakers and a headphone jack.
This page describes the hardware.
David
[Edit: update documentation link]
@DavidKlineMS Thanks for sharing the link.
I just checked it out and don't see anything for mic audio inputs.
Are you looking to access the HoloLens mic and record something to playback through the speakers?
Holograms 212 - Voice has a section that briefly walks through recording a message.
@AR123,
Under Sensors, the doc says "4 microphones".
David
Thanks for sharing the link!
sorta, I'm thinking more about setting up a microphone for potential use in pro audio studios.
Hey @AR123, did you ever find a solution for this?
404 link.
Does the headphone jack also support mic line in?
Microsoft HoloLens Agency Readiness Program Partner
Developer, Immersive Experiences at Valorem | LinkedIn Profile
Moderator for Microsoft's open source HoloToolkit for Unity
In place fixed the hardware documentation link. Including it here as well.
I do not believe the headphone jack also supports mic in, I will double check.
David
The Hololens development edition does not have or support mic line in. You have to rely on the built-in mic.
Hi, is there a way to get audio output feedback ?
My goal is to get a message like "Room Saved" after let's say saving the room mesh.
EDIT: Once again I have found what to use after writing my question.
There is a TextToSpeech script in the holotoolkit which seems appropriate for my design.
