Align to surface normal
Hi! I am developing with holotoolkit, I am placing object with SpatialMappingObserver, SpatialMappingManager and WorldAnchorManager like managers, and the objects I want to place they have "TapToPlace"
My cuestion is: When I am placing one object, this object is face to face with camera and works nicely with spatial surfaces, that is OK. But the thing I want to do: When the object (for example a plane) touch a wall, I want this plane aligns with the wall normal.
I cant find the script for this. When I run microsoft app and I am positioning the window, this window works that I am asking for. I want for my scene planes. I appreciate the help!!
Regards.
    Hi @gomes
    I think basically you just want to set your transform.up vector to match the normal of the surface you are putting it on. The spatial mapping mesh might be a little noisy to use directly; using plane finding would be better. There is some good discussion here though it isn't HoloLens specific.
    Thanks for your help, my problem is that I dont know how and where catch this spatial surface for acces to his normal.
    GazeManger.Instance.Normal will give you the normal of the surface that your gaze intersects with.
    I think I know what you want. Use serfacemeshestoplanes script, generate planes in your environment, then place objects on those planes. You can get some help from holograms 230. (Placeable script)
    Hey, I'm a Microsoft Student Partner and a Mixed Reality Project Manager at a game development studio. I'm here to inspire and get inspired. Cheers.
