Hololens Emulator not appearing as a debug target
I do not see the Hololens Emulator in the list of target devices. I see the mobile emulators, local machine, simulator and remote machine as targets.
Here is a screenshot: http://screencast.com/t/WQVeCVyx
Some information about my setup:
- Running on a Surface Book (i7 256GB dGPU)
- I updated from VS2015 Update 1 running UWP Tools 1.2 to Update 2
- I installed the Hololens SDK after before VS Update 2 but then uninstalled it and reinstalled after Update 2 was done.
- I have no problem running Windows 10 Mobile emulator
Here are some relevant facts:
- I've tried both a 2D and a 3D SharpDX "File > New" project with a build configuration of x86
Here is my VS info:
--- Microsoft Visual Studio Enterprise 2015: Version 14.0.25123.00 Update 2
--- Visual Studio Tools for Universal Windows Apps 14.0.25123.00Here is my Hololens installation info:
--- Microsoft Hololens Emulator v 10.0.11082.1039
--- Emulator Image v 10.0.11082.1039
What did I miss and how can fix this?
Lance
Microsoft MVP - Windows Development
More about me and my credentials
Actually, you're on a surface book - I have problems with mine as well. I had to disable one of my GPU's didn't matter which one. That allows you to start it.
Try creating a C++ Holographic project and seeing if the emulator shows up. This may kick start it.
Dwight Goins
http://dgoins.wordpress.com6 -
OptionsLance ✭
UPDATE: I found the cause of the problem for when the emulator doesn't appear as a debug target.
The problem only happens for projects that have 10586 as **both ** the Min and Target SDK version
Fix: Make sure you have 10240 as your MinTarget SDK version (find this in the project properties)
This is a temporary workaround as the team has identifies the underlying cause and will fix it asap.
More about me and my credentials6
Have you checked this:
In the BIOS, the following features must be supported and enabled:
Hardware-assisted virtualization
Second Level Address Translation (SLAT)
Hardware-based Data Execution Prevention (DEP)
Also if Hyper-V is installed?
I can run other emulators, Hyper-V isn't the problem.
I've run into this a few times and the only thing that helped was restarting VS and/or sometimes re-generating the csproj. Repairing the emulator install from add/remove programs also fixed it once.
Another time, running the emulator independently (shortcut below) got it to show up as a target next time I started VS.
"C:\Program Files (x86)\Microsoft XDE\10.0.11082.0\XDE.exe" /name "HoloLens Emulator 10.0.11082.1039." /displayName "HoloLens Emulator 10.0.11082.1039" /vhd "C:\Program Files (x86)\Windows Kits\10\Emulation\HoloLens\10.0.11082.1039\flash.vhd" /video "1268x720" /memsize 2048 /language 409 /creatediffdisk "C:\Users\AppData\Local\Microsoft\XDE\10.0.11082.1039\dd.1268x720.2048.vhd" /fastShutdown /sku HD
UX Designer @ Anki
Dwight Goins
How did you disable it, detach the keyboard or use the NVIDA tool to explicitly choose the dGPU for the Hololens XDE?
I've done a complete uninstall and reinstall of everything, did a fresh "File > New" and it still doesn't show up.
The full path gives me an error about an XML file being missing, but when I run it from an elevated CMD prompt, I don't get anything.
I will try another emulator repair and instead of a File > New, use the Galaxy Explorer app.
This did the trick, thanks!
To disable the dGPU, I just went to device manager and disabled one of the display adapters. Let me see if the NVidia tool will work as well... Thanks for the tip on NVidia I had totally forgotten about that!
Update: That worked... using the NVidia tool keeps me from having to disable the dGPU in Surface Book - sweet!
Dwight Goins
cc @Dwight_Goins_EE_MVP
