Spatial Mapping Late Render
I try made project with spatial mapping. But when i debug on my hololens device spatial mapping will late render and my object (a CUbe ) will be hide under map. It's normal? I using spartial Mapping From Holo toolkit Github
I think StartObserving is the method that is called when it gets ready. You could add an event there so you propagate the action.
Then you just register a listener and wait. That listener is a method creating your model or starting the placement.
5 -
@LucasSoftability said:
I think StartObserving is the method that is called when it gets ready. You could add an event there so you propagate the action.Then you just register a listener and wait. That listener is a method creating your model or starting the placement.
Thanks
SpatialMapping object has a bit of latency before being initialized. You should maybe wait or use a event/listener to wait for the Observer to be ready. I think if you add your logic in the StartObserving method of SpatialMappingObserver, you should be able to get the moment when it is ready to be used.
What's the trigger or time to create all object?
Thanks
