Cannot use HoloLens Emulator
achille
When I chose HoloLens Emulator instead of Local Machine in the target device tab, don't get nothing. Just like I haven't click, the text remain Local Machine altough I've clicked.
I've installed VS R2, Unity Beta for HoloLens and HoloLens Emulator and I've Hyper-V enabled. On the Microsoft tutorial 101, they click on HoloLens Emulator and they wait 10 second and the right text appear. How do I fix this problem?
[EDIT]It works if I use Local Machine as target device
I'm from Italy, sorry if I made any mistake in the text
On some systems the write up says it can take as long as 15 minutes to first start up. If you're not getting any errors, and you have successfully installed vs.net 2015, update 2, tools, and emulator, and you have at least windows 10 Pro and above edition, it should work.
What are you computer specs?
Dwight Goins
http://dgoins.wordpress.com
The problem isn't at the startup. I can't even chose the HoloLens Emulator from the list.
My PC specs are:
Windows 10
8GB RAM
500GB (60GB of free space)
Intel i5 CPU
Nvidia Geforce GTX 980 GPU
First try to create a C++ Holographic project, compile it and see if you can select HoloLens emu, if not, I would reinstall Update 2 and Tools.
Dwight Goins
Ok I will reinstall them and I'll let you know
Do I have to reinstall Unity?
Unfortunately yes, I found that the list in Install the tools
What looks very specific instruction sequence. I found even though VS 2015 said it was update 2. Control Panel. VS 2015 was declared as Update 1. So I uninstalled everything and started again by installing using the version on the install page.
Remember to do custom VS2015 install and tick/check Tools 1.3 and the UWP Windows 10 SDK. This is then detected by Unity HoloLens 5.4.0b10-HTP (64-bit) on install.
Ok, Thank you
Internet in my countri is really slow so maybe it will be ready by tomorrow
Ok. I did reinstall everything (Internet helped me this time ) but it still doesn't work
Me too, I also have this problem. It looks like reinstall does not work. Is there any way to run the emulator standalone, outside of Visual Studio, so we can test?
Does anyone hava a solution to this?
Why do you run it on Local Machine ? You should pick Emulator
also be sure that you've turned on Hyper-V in "feature on/off settings" in your system
Sorry, you don't understand. I must run it on Local Machine (I don't want to, because I can't use any Hololens function). When I pick the Emulator from the target device list, it is like I haven't even clicked. It doesn't do nothing. Also, I have Hyper-V enabled and as DatVM said on StackOverflow (http://stackoverflow.com/questions/36434087/cannot-choose-hololens-emulator-as-debug-target-in-visual-studio) "in Hyper-V, cannot see any virtual machine in the list".
