How to align the game objects in front of you?
On Reset and on Start I am attempting to have a body I created in Origin appear in front of me. I created 3 bars and attach the following code to each of them. The general idea is storing the location parameter and in OnReset function put them back to original place. All the cubes belongs to a same collection. And they are well aligned with each other in default. The result is the 3 bars appear misaligned with each other. The third bar always shows an angle with respect to other bars. That's wield because they share the same code.
using UnityEngine;
public class SphereCommands : MonoBehaviour
Vector3 originalLocPosition;
void Start()
    // Grab the original local position of the sphere when the app starts.
    originalLocPosition = this.transform.localPosition;
    if (!this.GetComponent<Rigidbody>())
        var rigidbody = this.gameObject.AddComponent<Rigidbody>();
        rigidbody.collisionDetectionMode = CollisionDetectionMode.Continuous;
// Called by GazeGestureManager when the user performs a Select gesture
void OnSelect()
    // If the sphere has no Rigidbody component, add one to enable physics.
// Called by SpeechManager when the user says the "Reset world" command
void OnReset()
    // If the sphere has a Rigidbody component, remove it to disable physics.
    //var rigidbody = this.GetComponent<Rigidbody>();
    //if (rigidbody != null)
    //    DestroyImmediate(rigidbody);
    // reset the bar position and make it with rigidbody
    this.transform.localPosition = originalLocPosition;
    // Put the sphere back into its original local position.
// Called by SpeechManager when the user says the "Drop sphere" command
void OnDrop()
    // Just do the same logic as a Select gesture.
    OnSelect();
