Manipulate object (re-size/scale and move) on gesture commands
Hi folks,
I'm trying to put together a quick POC to be able to move and resize/rescale an object. I came across this link: http://blog.ickydime.com/2016/05/hololens-manipulate-gestures-and.html
and trying to implement it but with no luck. Has anyone else implemented something similar that they would be able to share?
thanks in advance.
HoloSheep mod
@itsmehuey if "quick" is the priority you might start with using voice keywords like "bigger" and "smaller" to scale to get you started and use the TapToPlace for moving the object if you are running into issues implementing the different modalities for gestures to handle multiple interactions.
In case it is of any help, here is a thread with some basic steps to create a project with that kind of interaction from scratch.
Thanks @HoloSheep that actually wasn't such a bad suggestion. Worked fine.
