Cannot input Emulator Hololens
Helo i have deploy my project on emulator. But
this
Walk forward, back, left, and right - Use the W,A,S, and D keys on your keyboard, or the left stick on an Xbox controller.
Look up, down, left, and right - Click and drag the mouse, use the arrow keys on your keyboard, or the right stick on an Xbox controller.
Air tap gesture - Right-click the mouse, press the Enter key on your keyboard, or use the A button on an Xbox controller.
Bloom gesture - Press the Windows key or F2 key on your keyboard, or press the B button on an Xbox controller.
Hand movement for scrolling - Hold the Alt key, hold the right mouse button, and drag the mouse up / down, or in an Xbox controller hold the right trigger and A button down and move the right stick up and down.
Not working. What the problem is this?
fliP ✭
Have a look at that: https://forums.hololens.com/discussion/952/no-input-from-emulator
I do have the same problem. However I have no proxy servers in use, so that doesn't solve the problem for me. I do encounter this issue only when I am connected to my personal wifi at home. Then:
- no input is possible because the simulation isn't able to connect
- the device portal can't be reached (timeout)
- deploying apps isn't possible because Visual Studio can't connect either
There is no issue when connected to other wifi networks. Also when I connect my computer to my home network via Ethernet, everything works just fine. So it's neither a general wifi nor a general network problem - it appears only when connected to a specific network via wifi. Does anyone have a clue which settings might be responsible for that?
5 -
@fliP said:
Have a look at that: https://forums.hololens.com/discussion/952/no-input-from-emulatorI do have the same problem. However I have no proxy servers in use, so that doesn't solve the problem for me. I do encounter this issue only when I am connected to my personal wifi at home. Then:
still cannot fix it
still cannot fix it
I reinstall my PC and VS also emulator it's worked now
