Hololens Cannot Boot
Hy guys my hololens cannot boot. I have pluged charge until 30 Minute and still cannot boot. I press button power 10 Second just show pop up hello and blank again. Nothing To DO
What's the problem?
OptionsDavidKlineMS mod
@christsaragih,
I recommend contacting HoloLens Support via the link at the bottom of this link if you are still having issues booting.Thanks!
David5
@christsaragih
Here is what the support page says on the subject:
Similar advice on the troubleshooting page.
I have run into the same scenario a number of times in the past and in each case I found that after a few deep breaths and then summoning up a couple of calm re-attempts the device eventually began to cooperate and reboot again.
My recommendation is to try the above steps again and see if that helps before contacting support (bottom right corner of this page).
HTH.
I Have try full device recovery and stuck on this (see ScreenShoot) @HoloSheep
update @HoloSheep I have finish recovery, but my hololens still cannot boot
What's wrong?
@christsaragih,
David
