Previously spatial mapped background
Hi! I was just wondering if there is any way I can use a previously mapped space as background for a hologram.
I also would like to know if there is already a man-shaped hologram somewhere.
thanks
@angelicaHolo
Not sure I understand your first question, but for your second question it sounds like you are looking for sources of 3D models.
There are many sources on the web, but two easy and reliable ones that have many free models to get you started are:
Search for things like man, guy, male, dude
HTH.
Hi! thanks for your answer.
i guess my first question is quite confusing. but what i would like to try is to map a space using the spatia mapping, save the information and then use that space as a sort of background for a hologram,
It will be like taking a video then add a hologram to that video...
If I understood correctly, you can save the room using the Device portal. You scan the room and you save a .obj file you can load in Unity, and a .xef file if you want to test it with the emulator. You will find all informations there: http://hololenshelpwebsite.com/Blog/EntryId/1009/Capture-A-Real-Room-For-The-HoloLens-Emulator
thanks!
You're welcome!
