how to use the hololens emulator?
Do i need a webcam for the emulator, so it could recognize the gesture of my hand or gaze input, may be need a mic too?
Jimbohalo10 ✭✭✭
Here are the links to HoloLens Emulator Gestures using keyboard and mouse
The HoloLens emulator Basic emulator input
Full instruction on using HoloLens Emulator
Using the HoloLens emulator5 -
HoloSheep mod
@xinyan if you have not come across it already the advanced emulator input key information can be found here: https://developer.microsoft.com/en-us/windows/holographic/advanced_emulator_input
You can only emulate the gestures via the keyboard and mouse. You could use a microphone with Cortana. However this may be difficult on the emulator. The physical headset has a holographic camera that cannot be simulated
Can you tell me where i can find the key map to the gestures? what i knew is key a or spacebar means a selection.
@Jimbohalo10
Can you tell me where i can find the key map to the gestures? what i know is key a or spacebar means a selection.
https://developer.microsoft.com/en-us/windows/holographic/using_the_hololens_emulator
@Fixus Than you
