I would like to know, how to communicate b/w two hololens which are remotely placed ?
I have followed many threads which are categorized under sharing tag but couldn't find a suitable answer. All that i was able to find out was that one can use Azure / UNET for communicating remotely. Any help will be highly appreciated .
Thank you.
@bharat1995 said:
transfer simple data as of now ....like the transform etc . But in asynchronous collaboration we might a lot other stuff.. which i haven't thought about now :P.You can use SignalR but you need a owned server application.
A good alternative is Firebase by google. I succesfully used it in a simple chat application. Firebase implements the publishing and subscribe design pattern.5 -
Hi, I am writing in this thread so that any one who is looking for remote connection of HoloLens doesn't get stuck without any answers. I basically spent hours searching the net as in how to achieve this. Hope this helps.
Firstly make sure that u follow all the instructions mentioned in the 240 sharing course. Then create a sharing service in an open n/w (issue which many of you guys will not face..:P) and try connecting both the HoloLens to the same IP. For testing u can use their sample application.
For any further doubts, u can ask questions in this thread.
mark_grossnickle ✭✭✭
Yes, I can confirm it does work non-locally. We ran the sharing service on a server with a static IP address and then devices can connect to it anywhere using that IP. The main issue is making sure the firewall is open on ports used in sharing.
8
@ahillier can you provide any help regarding this. Any documentation or a hint as to how to achieve it ..?
What do you mean with "communicate"? Do you want to transfer simple data or want to share the holographic objects?
transfer simple data as of now ....like the transform etc . But in asynchronous collaboration we might a lot other stuff.. which i haven't thought about now :P. Mainly i want help in UNET. I am going through some tutorials in UNET from youtube. Will post here if i get stuck during development. Thnx !!
@bharat1995
You said, that you use the SharingService from the HoloToolkit. Does this also work non-localy? If yes, how?
