I would like to know, how to communicate b/w two hololens which are remotely placed ?
I have followed many threads which are categorized under sharing tag but couldn't find a suitable answer. All that i was able to find out was that one can use Azure / UNET for communicating remotely. Any help will be highly appreciated .
Thank you.
    @ahillier can you provide any help regarding this. Any documentation or a hint as to how to achieve it ..?
    Thank you.
    What do you mean with "communicate"? Do you want to transfer simple data or want to share the holographic objects?
    transfer simple data as of now ....like the transform etc . But in asynchronous collaboration we might a lot other stuff.. which i haven't thought about now :P. Mainly i want help in UNET. I am going through some tutorials in UNET from youtube. Will post here if i get stuck during development. Thnx !!
    @bharat1995
    You said, that you use the SharingService from the HoloToolkit. Does this also work non-localy? If yes, how?
