adding shadows to objects is missing
Jerome
there is no shadows for the objects.
this breaks the quality of the videos.
I'm not looking for a detailed shadow which follows the floor, but just a simple blured shadow in option.
for example I use the dinosaur, but he is floating in the video due to the lack of shadows.
I was just setting up a scene in realize the shadows are going as well. Has there been any updates of this? I no longer find it is an option in the UI
@Jerome
The color presentation with HoloLens is inherently additive.
Currently, there is no way to subtract lights from the scene you see.
You cannot hide totally a real object behind a Hologram or Actiongram.
